Sensory ciśnienia w kołach
AluStar
Model: GT500
Post autor: AluStar » 2009-12-24, 14:36
Ma ktos czujnik do sprzedanai 1 szt .
Jezeli by komus wywalilo blad spowodowany awaria czujnika badz Oderwaniem sie go od felgi !! to juz potem po zalaczeniu zaplonu swieci sei kontrolka. Zdarzyc sie moze ze opaski metalowe trzymajace czujniki puszczaja i wtedy czujnik moze sei odkleic od felgi.
Przy zdejmowaniu opony uwazac aby mechanik nie rozwalil, zerwal czujnika : fabr znajduje sie po przekatnej wentylka.
AluStar
Model: GT500
Post autor: AluStar » 2009-12-24, 15:23
KAZDE Z CZUJNIKOW SA WYPOSAZONE W BATERIE KTORE DZIALAJA OD 5-10 LAT
Wiecej i dokladneij w tym artykule.:
http://www.aa1car.com/library/tire_monitors.htm
AluStar
Model: GT500
TPMS Programowanie - Sensory ciśnienia w kołach
Post autor: AluStar » 2011-03-08, 09:05
2008 Ford Crown Victoria / Lincoln Town Car / Mercury Grand Marquis
2008 Ford E-series
2007-2009 Ford Edge / Lincoln MKX
2005-2008 Ford Escape / Mercury Mariner
2007-2009 Ford Expedition / Lincoln Navigator
2006-2009 Ford Explorer / Lincoln Aviator / Mercury Mountaineer
2007-2008 Ford F150, F250, and F350 / Lincoln Mark LT
2009 Ford Flex
2008-2009 Ford Focus
2006-2007 Ford Freestar / Mercury Monterey
2008-2009 Ford Fusion / Lincoln MKZ / Mercury Milan
2007-2009 Ford Mustang
2007-2009 Ford Ranger
2008-2009 Ford Taurus / Mercury Sable
1. Make sure all tires are inflated to the vehicle’s recommended inflation pressures (found in
the owner’s manual on the door placard).
2. Turn the ignition switch to OFF then press and release the brake pedal.
3. Turn the ignition switch from OFF to RUN (engine OFF) 3 times, ending in the RUN
position. Do this within 10 seconds.
4. Press and release the brake pedal.
5. Turn the ignition switch back to OFF.
6. Turn the ignition switch from OFF to RUN (engine OFF) 3 times, ending in the RUN
7. The horn should sound letting you know the vehicle has entered into TPMS relearn mode
8. Place the VT10’s antenna on the sidewall of the driver’s side front tire 180 degrees from
the valve stem.
9. Hold the right button of the VT10 triggering tool for 5-10 seconds. The vehicle’s horn will
sound letting you know the sensor has been learned.
10. Once the horn sounds, move on to the passenger side front tire and repeat the process.
Each tire should only take 30 seconds.
11. After the passenger side front tire has been learned, continue on to the passenger side
rear tire and finishing with the driver’s side rear tire.
12. You may now turn the ignition to OFF. If the horn does not sound, the sensors were learned
successfully. If the horn sounds twice, then the process must be repeated because there
was a malfunction.
Koral
Model: GT CS8 +500HP
Re: Sensory ciśnienia w kołach
Post autor: Koral » 2011-03-08, 09:36
a wlasnei rozgladalem sie za felgami 19" do bordowego.. co musialbym zrobic zeby nie waywalalo błędu, ewentualnie czy da sie przelozyc te sensory?
Koral tel.+48 792-33-55-65
AluStar
Model: GT500
Post autor: AluStar » 2011-03-08, 10:04
Sensory tak - bez problemu. Tylko jest problem z Opaskami - sa zanitowane i niema mozliwosci ich ponownego zalozenia. Cuda wyprawialem aby takie opaski zdobyc w PL ( dalo sie ale nie 4 szt tylko 1000 szt ). Nawet stosowalem laczone opaski ale je rozwalalo ( sila odsrodkowa ) wiec radze kupowac odrazu z felgami napewno opaski .
Uwaga : W sprzedaży sa opaski za szerokie ktore nie mieszcza sie w przelotki od sensorow. Wiec radze kupowac OEM.
Hans
Model: 500
Post autor: Hans » 2011-03-08, 10:39
koral pisze:a wlasnei rozgladalem sie za felgami 19" do bordowego.. co musialbym zrobic zeby nie waywalalo błędu, ewentualnie czy da sie przelozyc te sensory?
Przełożyć się da, ale tak jak napisał AluStar, jest problem z opaskami. Proponuję ścigać felgi z Ameryki - np. na AmericanMuscle można zamówić felgi z już założonymi opaskami i czujnikami.
Koral
Post autor: Koral » 2011-03-08, 11:13
Hans pisze:
pytanie czy dojda do zlotu :( no a ktore z americanMuscle bys polecil? bo boje sie ze maja tandete z chin,zreszta oni wiekszosc maja albo made in taiwan albo china ..
Hans
Model: 500
Post autor: Hans » 2011-03-08, 11:52
No do zlotu raczej nie dojdą. ale te, co masz obecnie są i tak spoko, więc nie wiem, czego się czepiasz.
Moim zdaniem bardzo ładnie by wyglądały te felgi, ale wszystko jest sprawa gustu, a wiadomo, że każdy ma inny. ;)
Koral
Post autor: Koral » 2011-03-08, 12:34
no ladne.. a co znaczy Gunmetal?
AluStar
Model: GT500
Post autor: AluStar » 2011-03-08, 12:52
koral pisze:no ladne.. a co znaczy Gunmetal?
Taki szary kolor..
Ja mysle ze dojda ..
http://www.americanmuscle.com/universal-tpms-bands.html" onclick="window.open(this.href);return false;
te sa ok - ja je kupowalem - pieknie pasuja i nie sa za szerokie..
Koral
Post autor: Koral » 2011-03-08, 13:37
opaski pewnie u nas nie problem wiec same czujniki przyszlyby w tydz lotnicza:)
AluStar
Model: GT500
Post autor: AluStar » 2011-03-08, 13:52
koral pisze:opaski pewnie u nas nie problem wiec same czujniki przyszlyby w tydz lotnicza:)
Tez tak myslalem - moze sie zorientuj czy nie problem - bo dla mnie bylo to zaskoczeniem .
A chyba ze chcesz kupic 1000 szt - to tak - zrobioa ci takie dlugie ..
Scania
Model: GT 2008
Kolor: UA black
Post autor: Scania » 2011-03-08, 18:01
jak coś to mam nówki 4 sztuki uchwytów do sensorów. Mogę odstąpić ...
Opaski zamawiałem z firmy WURTH i pasują, więc trzeba dokupić tylko sensory. Pilota do zaprogramowania też mam, mogę pożyczyć.
Koral
Post autor: Koral » 2011-03-09, 11:05
Scania pisze:jak coś to mam nówki 4 sztuki uchwytów do sensorów. Mogę odstąpić ...
a to te opaski pasuje na rozne rozmiary kol? to moze u mnei wystarczy przelozyc opaski z 17" na 19" z czujnikami?
sławekw
Post autor: sławekw » 2011-03-09, 12:11
koral pisze:a to te opaski pasuje na rozne rozmiary kol? to moze u mnei wystarczy przelozyc opaski z 17" na 19" z czujnikami?
Pytanie czy mają odpowiednią długość. Jeżeli tak, to pewnie da rade.
Wróć do „4,6 V8 2005 - 2010”
