Gałka dźwigni zmiany biegów (automat)
skrzynia, wał, tylni most
artu-41
Model: Mustang V6 manual
Kolor: szary
Post autor: artu-41 » 2015-06-01, 11:19
Jak w temacie jak to odkręcić - jest tam z tyłu otworek i domyślam sie że tam jest wkrętka na imbus tylko że nie mogę dopasować żadnego imbusa - chcę wymieić ten uchwyt na aluminiowy i myślałem że będzie to prosta sprawa.
(George Carlin)
Re: Gałka dźwigni zmiany biegów (automat)
Post autor: Rezor » 2015-06-01, 11:50
z opisu na cjponyparts:
After you have turned your key(s) to the on position, simply move your shifter lever to either the 2 or 1 gear and be sure to set your parking brake. On the side of the shifter facing the dash / bezel, near the bottom of the shifter you will feel a small indention; this is a small screw (similar to the same one on the new Billit shifter but in a different location.) Now some are philips head screws, some are allen wrench style so you may want to grab both and then see which one you need. Once you unscrew that retainer screw, be very careful not to let the button "pop out" as you remove the old shifter. Once you have it removed, make sure you new Billit shifter is assembled and simply mount it on the shift lever stick and then tighten the retaining screw slightly and then check and make sure the button engages the shifter in all gears; If it does not, slide it back up and reposition til it does. Once you check all gears are good to go, simply make sure you completely tighten the retaining screw and now you can enjoy the sweet new Billit shifter! Serious Ultra-mega action cool!
artu-41
Kolor: szary
Post autor: artu-41 » 2015-06-09, 19:49
Gałka zrobiona !!! Teraz jest amelinum :cwaniak:
(George Carlin)
Post autor: Rezor » 2015-06-09, 19:58
Gratuluje! Wrzuć jakąś fotkę :)
artu-41
Kolor: szary
Post autor: artu-41 » 2015-06-15, 21:44
Proszę bardzo gałeczka aż lśni !!!
(George Carlin)
Post autor: Rezor » 2015-06-15, 21:57
radyjko oryginał? :) u mnie wala się jakaś chińska podróbia "piajonierra" :( Pęknie się prezentuje :)
artu-41
Kolor: szary
Post autor: artu-41 » 2015-06-15, 22:12
I ładnie gra !!
(George Carlin)
smerf
Post autor: smerf » 2015-06-15, 22:53
artu-41 pisze:Proszę bardzo gałeczka aż lśni !!!
Zimą ci ręka przymarznie do tej gałki :D
artu-41
Kolor: szary
Post autor: artu-41 » 2015-06-15, 23:42
Faktycznie tego nie przewidziałem - na szczęście w zimie prawie nie jeżdżę.
(George Carlin)
smerf
Post autor: smerf » 2015-06-16, 00:00
A w lecie jeszcze gorzej,, jak z jaką dupą pojedziesz i potem ją złapiesz za rękę, to pomyśli żeś nieboszczyk :D
Post autor: Rezor » 2015-06-16, 00:45
Zima 2015. artu-41 umieszcza na forum tutorial "jak obić aluminium skórą" :D
artu-41
Kolor: szary
Post autor: artu-41 » 2015-06-16, 09:42
Choroba!!! Będę musiał pomyśleć jak podłączyć podgrzewanie do tej gałki bo obszywać skórą to się mija z celem!! A dziewczyny to lubią takie świecidełka, taka ich natura :ok:
(George Carlin)
