Kodowanie pilota +2005
Moderatorzy: Hans, Hans, Hans
Stachu_xjr
Model: GT 2016
Post autor: Stachu_xjr » 2009-05-31, 12:47
Najprawdopodobniej rozkodował mi sie centrlany zamek po zalaniu centralki , czy jest jakś sposób na kodowanie pilota od nowa ( lub jakaś firma najlepiej ze Śląska co mogła by dac sobie rade z tym )
Pawellos
Model: 2009 Mustang GT
Kolor: Candy Apple Red
Post autor: Pawellos » 2009-05-31, 17:51
Możesz go sam zaprogramować, jeśli tylko masz kluczyk zaprogramowany do stacyjki (zakładam że to Ci się nie rozkodowało)
Kod: Zaznacz cały
Note: Ensure the brake pedal is not
depressed during this sequence.
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the ignition.
3. Cycle eight times rapidly (within
10 seconds) between the 1
(OFF/LOCK) position and 3 (ON).
Note: The eighth turn must end in the 3 (ON) position. The doors will
lock, then unlock, to confirm that the programming mode has been
activated.
4. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
5. Repeat Step 4 to program each additional remote entry transmitter.
6. Turn the ignition to the 1 (OFF/LOCK) position after you have
finished programming all of the remote entry transmitters. Note: After
20 seconds, you will automatically exit the programming mode. The
doors will lock, then unlock, to confirm that the programming mode has
been exited.
Stachu_xjr
Model: GT 2016
Post autor: Stachu_xjr » 2009-05-31, 20:04
DZIAŁA DZIAŁA SERDECZNE DZIEKI :padam: :padam: :padam:
